F Faizan_8 Reputable May 1, 2016 15 0 4,520 Jan 31, 2018 #1 COOLER MASTER MASTERLIQUID LITE 120 is it good for FX-8350
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Jan 31, 2018 #2 It'll work and it's better then the stock cooler however there are better air options for the same price as long as your case can fit them. Upvote 0 Downvote
F Faizan_8 Reputable May 1, 2016 15 0 4,520 Feb 1, 2018 #3 WildCard999 : It'll work and it's better then the stock cooler however there are better air options for the same price as long as your case can fit them. My Case Can Fit any Cooler. All about my Case https://www.amazon.in/Artis-Gaming-Cabinet-AR-155-without/dp/B075FQKFKV Upvote 0 Downvote
Zerk2012 Titan Ambassador Oct 6, 2014 22,079 2,282 104,240 Feb 1, 2018 #4 Your case will only fit a air cooler 160mm tall. Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Feb 1, 2018 #5 I'd probably go for the Be Quiet Dark Rock 3 over that AIO and it will fit that case. Upvote 0 Downvote
F Faizan_8 Reputable May 1, 2016 15 0 4,520 Feb 28, 2018 Solution #6 thank you really appricated Upvote 0 Downvote Solution
