For all of you Liquid cooling people ive got a fairly cheap solution to get you below ZERO C. I already had a liquid cooling setup, so keep in mind that im only including the cost of the new equipment.
5 cubic' compact freezer
20' X 2 of soft copper line
3 rolls of pipe insulation
3 rolls of insulated tape
3 rolls of electrical tape
I got the freezer brand new for $99.00 on sale. The line is the only other significant expense. It was less than $30.00 for 40' of line and you could get away with 20'. The advantage to the extra 20' roll is that you can leave it coiled inside the freezer and not even worry with a resivior. I would suggest using the extra roll as a coil and using a resivior. This way you can submerse the coil in a seperate res inside the freezer. You better study up on insulating the Mobo and CPU socket because this thing gets really cold. Ive had mine up and running for the past 4 days and the only problem that I have encountered is the liquid freezing when im not using the system. This can be easily avoided by either turning the frezzer setting to min or by using your system 24/7 folding for THGC
So far I have easily hit -10C and still have room to go lower. Im not going any lower until I get a new CPU waterblock that doesnt have an acrylic top like mine does. From what I hear Acrylic will crack at low temps. You will also need a heavy duty pump. I suggest an inline that is capable of 700 GPH or more. If you would like to see pics of my setup, PM me your e-mail addy.
ASUS P5WD2 Premium
Intel 3.73 EE @ 5.6Ghz
XMS2 DDR2 @ 1180Mhz
<A HREF="http://valid.x86-secret.com/records.php?PHPSESSID=792e8f49d5d9b8a4d1ad6f40ca029756" target="_new">#2 CPUZ</A>
SuperPI 25secs
ASUS P5WD2 Premium
XMS2 DDR2 @ 1180Mhz
SuperPI 25secs
