Recently, my G13 has had a type of "sticky key" issue. There is no grime in the key. I am quite certain this is a software issue, although I am having trouble discovering the source.
Periodically, ANY one of the G keys will "stick" and remain virtually pressed for a few seconds. While "stuck" no other input is received. Once "unstuck" normal input resumes (a few keys pressed during the "stiction" will accompany the last few keys among the "stuck" key)
This happens both in-game and out. Here is a sample of the "stuck" input copied from notepad:
"adasdadadasddasdasdasdasdwasdwasdasdwasdawdasdwasdawdawdwasdwawdwadawdasdwasdwadsadwasdwasdwasdwasdwasdwadsdwdsawdasdwdsawdsawdasdwasdwasdwadsdasdadasdwasdwasdawdadwasdwdasdwadsdawdadwadsdwasdawdadwasdsdawdawdsawdsawdsawdsawdsawdsadwasdwadwsdawdsadwawdawdsdwasdwadsdwadwdasdawdadsdwadsdwasdwaddwawdawdsadawdasdasdwadwadawdasdAWDASDWASDWASDAWDADWDAWDSawdasdawdsadwasdwasdwasdwasdwadwasdwadsadwasdwadsdwadsdwasdwadsdwdsawdsdwasdwdsawdasdwasdwadsdawdasdwasdwadsawdwadsdwadwadasdwadsawdsawdsdwdasdawdaWddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddAwddasdwasdasdwadsdwadsdwadsdwadsdwasdwasddsdsdsdasdasdwasdaw"
You'll notice normal input for a minute or so, including the use of the shift key. Toward the end, in this case, you see the "d" key is stuck. (Not physically stuck, but virtually stuck.) During this malfunction, I am continually pressing other keys at the same pace I had been through this test.
To rule a couple obvious things out:
-This issue does not happen with my standard keyboard.
-I have another G13 (brand new) and this same issue is present.
-This issue remains no matter the USB configuration I try.
-I have tried installing the last two versions, with no fix. (Currently on 9.02.65)
Info:
Running windows 10
Logitech Gaming Software version 9.02.65 64 bit
Mobo - Asrock z97 extreme4
This problem originated when I was moving my setup around the room. Perfect performance for many years. Moved the computer (unplugging all peripherals in the process). Plugged everything in and rebooted. G13 issue appears.
Info:
Running windows 10
