G
Guest
Guest
Archived from groups: alt.games.video.xbox (More info?)
After reading about how good Logitech wireless controllers are, I bought
four of them for my X-Box. The very first time I used them they worked
perfectly. Now they only work intermittently. For example, I'm playing
Halo and they all work fine at first, then someone all the sudden can't
control their character, then another person, then it will work again for
the first person, etc. I push the button on top of that thing that's plugged
into the X-Box and fool with it, and after a while I can get it to work.
Then eventually it will stop working or someone else's controller stops
working. The button doesn't seem to consistently do anything. I read the
instructions, they just don't seem to help.
Is anyone else having this problem? Is there a way to fix it? Is it
possible that my surround receiver, dvd, other electronic stuff, etc. could
be interfering with the signal?
Thanks.
Thanks.
