im planning on using every fan slot in my Cooler Master RC-690, except for maybe the upper side panel one.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
The problem is i want the case to run cool and quiet. The case can hold 7 fans total, but i plan on only having 2 intakes and 3-4 exhaust due to case design.
If you look at some of the pictures for the case, you'll notice that the front intake 120mm fan is blocked alot by the 3.5" HD bays. Depending on how easy they are to remove, ill take them out, but theres a good chance i wont. That, and a bottom mounted 120mm fan are the only intakes for the whole computer. (I am thinking 2 higher CFM fans here running always at 100%)
My processor heatsink is a Xigmatek Rifle 120mm.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
I plan on having its 120mm fan aiming to the back of the case, to shoot any hot air straight out the back 120mm, and any excess hot air will be sucked up by the top 2 120mm's.
Since i am going to SLI 2 8800GTS's, i was also thinking of adding 1 on the door (will experiment with this) and either suck air in or out.
So to sum it up... i want an average 120mm Case fan w/ no LED (if there is one maybe a simple one so i can clip its LED w/o much problem) with maybe 60-80 CFM, but 25-30 DBA.... (only problem w/ these numbers is that theres 50 of these on paper, but after reading reviews on most of the 120's, they never work out to be what they are on paper.
Basically im looking for fans that you guys already own, and love, and wish to recommend.
Im also not sure if i would want to plug these into the motherboard or if i should get a fan controller. I honestly would rather not, and just let them run at 100% all the time. I like to keep things simple.
