I am planning to build a SFF (as small as you can get with a triple-slot) and was wondering if you guys could give me some suggestions for cases.
The SSUPD Meshlicious and Cooler Master NR200 are really popular now and are relatively inexpensive and easy to build in. The Meshlicious has up to 4 slot GPU support if you sacrifice CPU air cooler height, but you can also run up to a 280mm AIO. The NR200 supports large CPU air coolers or 240mm AIO.I am planning to build a SFF (as small as you can get with a triple-slot) and was wondering if you guys could give me some suggestions for cases.
Thanks!Phanteks Eclipse 200A
Phanteks Evolv Shift 2
Thermaltake Tower 100
Beyond that, you would probably need to take a look at some of the less mainstream options like Dancase, though I think you will run into the common problem of not supporting triple slot cards.
