DashAhead :
Phillip Corcoran :
No, that's not the type of cable you want if you need more SATA power connectors.
If you just want to convert one existing SATA power connector to two SATA power connectors, you need this:
http://www.amazon.com/StarTech-com-PYO2SATA-Power-Splitter-Adapter/dp/B002N2EHVQ/ref=sr_1_1?s=electronics&ie=UTF8&qid=1403626973&sr=1-1&keywords=sata+y+power+splitter
That isn't exactly what I'm looking for. What I need is a 15 pin to 6 pin sata. Similar to the one in the original picture.
You need to get better at defining what you are looking for. There is no such thing as a 6 pin sata, refer to this site and figure out what the actual name of the connect you need is.
http://www.playtool.com/pages/psuconnectors/connectors.html
In general adapters are a sign you have screwed up somewhere else. If you need additional PCI-e cables you either lost some or are trying to run more than your PSU was built to handle.
As for what was said above, iceclock is wrong, adapters(like the one linked) cannot hurt your PSU. If you use them to give you connectors so that you can hook into more power hungry GPUs than your PSU can handle that is a different story, but the adapter will not hurt your PSU. You should not use modular cables that are not meant for your PSU though since they are often wired differently and could result in you having +12V and ground connected by accident.
