TL;DR, my new 2024 G14 battery seems to last 9 hours in cases where it seems like it should be lasting 10+ going by online reviews. Only difference is my ambient temperature is a bit higher. Trying to figure out if this is expected or abnormal.
Hello everyone,
I recently picked up an Open Box ASUS Zephyrus G14 2024 GA403UV. Have had it for less than 2 weeks. Ran some benchmarks and tests and everything seems to be good, except that the battery life I'm getting seems to be a bit under what I expected from reading and watching reviews. Not a huge amount mind you, but enough to be noticeable.
Specs: Nvidia Geforce RTX 4060, AMD Ryzen 9 8945HS, 16GB RAM, 1TB SSD, 2880 x 1800 3K OLED 120Hz display
Test 1: Silent Mode, "Best power efficiency" power mode, keyboard backlight off (on the lowest brightness setting which seems to turn it off), Brightness ~55%, Panel Power Saver On, Eco Mode in Armoury Crate GPU mode, Battery Saver auto-on at 20%, volume muted, only 3 startup apps enabled (Radeon Software Startup Task, ASUSSmartDisplayControl, SecurityHealthSystray), YouTube video playlist at 1080p
The first test I ran was the first time that I let the battery drain below 80%. I closed all apps and ensured there were no other apps running background processes (except for the standard stuff; processes that seem to be associated with ASUS, AMD, Armoury Crate, Microsoft, Realtek, Windows, etc.). Then I opened a single tab in Firefox to a playlist of YouTube videos (lectures 1-2hr long each), and set the YouTube resolution to 1080p. The battery drained from 96% to almost dead in about 6 hours, draining about 15% per hour. This seemed a bit off as most reviews seemed to claim about 7-9h under similar-ish conditions.
Test 2: Silent Mode, "Best power efficiency" power mode, keyboard backlight off (on the lowest brightness setting which seems to turn it off), Brightness 50%, Panel Power Saver On, Eco Mode in Armoury Crate GPU mode, Battery Saver on, volume muted, only 3 startup apps enabled (Radeon Software Startup Task, ASUSSmartDisplayControl, SecurityHealthSystray), completed all updates available on Armoury Crate & Windows settings & BIOS update from ASUS website, 1 long YouTube video at 720p
I came across a ShortCircuit video that gave very specific settings for their battery test (see 11:36), so I decided to run another test using similar settings. For those too lazy to click, their test specifies 20C, 72% brightness, silent mode, 60Hz, 2880x1800 resolution, 720p YouTube playback, and Windows Battery Saver Mode. To make my test more similar to the ShortCircuit test, this time, I turned battery saver on from the jump unlike last time, and put a single 10hr long YouTube video at 720p (the ShortCircuit video doesn't specify what videos they used, so I just used a 10hr marine life footage compilation in a tab on Firefox). I also went through and completed a bunch of updates listed in windows settings and Armoury Crate and also downloaded the latest BIOS from the ASUS website. I set the brightness to 50% exactly so that I should expect to get a result that would clearly beat the one in the video rather than relying on a result that would potentially be similar but where I would be second-guessing myself based on margin-of-error. Closed all apps except for 1 YouTube tab (the one I was using for the test) on Firefox like in Test 1. I expected a better result than last time not only because of the changes in tin caseshe test but also because I know that batteries typically perform a bit better once you have already discharged and recharged them a couple times (although this test was only the second time I had let the battery drop below 80%).
The laptop discharged from 100% to dead in about 9h10m. This is quite a bit less than the 9h56m tested in the video, even though my test was less strenuous due to lower screen brightness. The only differences in between the video test and my Test 2 that I can think of (aside from the ones I mentioned) are:
Hello everyone,
- The place I tested the laptop at sat at a temperature of about 24C instead of the video test's 20C.
- The laptop spent about 60% of the test sitting on carpet (although not very heat absorbent carpet, still probably more heat absorbent than a flat material), and the last 40% of the test sitting on a wooden desk. I assume the video test was probably done entirely on a table to avoid any heat-absorbing material.
