Hello there, I just bought Forza Horizon 3 (little late huhh 😉 ) , i downloaded the game through the windows store and started it for the first time today, sadly I have a problem , the fps is too low and it is unplayable (around 10-20 max) no matter what i do the fps stays almost the same, whether it was on ultra or low...I tried the "task manager fix" and I also check the GPU drivers and they are up to date, I also turned off the shader cache in the Nvidia control panel and at the same time i turned the Power managment mode to prefer maximum performance...
My Specs:
Gainward GTX 970
i5 6600k 3.5-3.9 Ghz
16 Gb of RAM
The GPU drivers are 398.11
I am currently running Windows 10 Version 1803
Every answer will be much apreaciated!
My Specs:
Gainward GTX 970
16 Gb of RAM
