Hello, yesterday I "upgraded" from an FX 8300 to a ryzen 1500x but for my surprise the FPS are similar or worse. In all my tests I've noticed that the CPU is the bottleneck.
Is this the normal performance of a Ryzen 1500x?
Could be that the CPU is defective? I purchased it used on aliexpress for $55 https://es.aliexpress.com/item/32917806151.html?spm=a2g0s.9042311.0.0.485563c04qQhV9
Any recommendatios? 🙁
Things I did after the upgrade
-Formatted and reinstalled windows 10 pro.
-Installed latest Nvidia drivers, Realtek HD Audio drivers and Asrock all in 1 Drivers for Ryzen.
-Installled all VC redist and DirectX
Games I've tested so far (minimum graphics settings to discard GPU bottleneck)
Assassin's Creed Unity Hovers at 45-50 FPS with huge random lag spikes.
The witcher 3 - hovers at 40-50 FPS
Assassin's Creed Syndicate hovers at 40-60 FPS
GTA IV hovers at 60 FPS with lag spikes (Sliders at minimum)
Mi current specs are:
Ryzen 1500x @stock (OC doesn't fix anything)
Arctic Freezer 33 eSports Edition
Asrock B450M-HVD r4.0 BIOS P3.10
Kllisre 16gb DDR4 2666mhz 17-17-17-39 single channel (No the best but I was on a budget)
Zotac 1050 TI OC Edition 4GB GDDR5
Power supply 550W Cooler Master
Assassin's Creed Unity Uplay Original
The Witcher 3 (GOTY) Original Steam
So a friend of mine lend me his Kingston 8gbx2 DDR4 2666mhz CL16-15-15-15 and here are the results.
AIDA64 Memory benchmark (Before around 21000MB/s)
The witcher 3 FPS barely improved by 1-5 (Lowest was 41fps)
Assassins creed Unity (Decent improvement around 5-10FPS but still are low FPS and GPU isn't at full)
Assassins creed Syndicate (Quite a huge improvement lowest was 71FPS)
So after the tests in dual-channel I'm certainly dissapointed memory benchmark showed a good improvement, but ingame the performance gain was just meh, this was meant to perform like an old six gen i5-i7, and is performing in games as good as my old FX8300@4.2ghz, Do you have other ideas of the performance issues, I'm afraid that the CPU could be defective or something.
