Hello, I’m getting low GPU usage and low FPS every single game(except cs2 is around 90% (full setting and 170-200 fps which i think it’s low?))
It doesn’t matter what setting I’m using. I’m trying every game low/ultra, 1080p or 1440p, DLSS on/off. In low gpu usage down a little bit but fps stays same.
I try with every game I have (cs2, Apex Legends, Call of Duty, Rust, Forza, GTA 5) but I only have a couple of screenshots.
I run 3dmark Spy Test and while gpu is testing it hit 100% usage. But later today I run furmark burn test for 20 minutes, most of the time I got 100% and 210 fps but I realized sometimes it dropped 70% usage and when that happened fps down around 160.
Recently a well known youtuber from my area uploaded fps test for the same gpu and every game he got 99% usage and much higher fps(some of them same games I have)
My previous rig had 100% cpu usage every time so I don’t think I have CPU bottleneck. And I know people are selling lower cpu’s with same gpu and there is no bottleneck.
The only thing that isn’t new in the system is the PSU.
I have 2 different GPU output from psu(not modular) and connected them into converter I got from inside GPU box(sorry for bad english
Only problem I can think psu is not enough but if so why I got 99% usage in test? (I’m not an expert just thinking)
My rig:
CPU: Ryzen 7 5700X
GPU: MSI RTX 4070 Gaming X Trio
MOBO: MSI B550 Gaming Plus
RAM: Kingston Fury Beast 32 GB 3600MHz CL18
SSD: Samsung 980 Pro 1 TB
PSU: 750W 80+ Bronze
OS: Windows 11 Pro
Monitör: 1440p 165Hz and 1080p 144Hz
Screenshots from rust and cod with on/off DLSS (fps wont change but you can see while it’s off usage is little bit higher)
https://ibb.co/VBTYWKL -
https://ibb.co/0hW7gT5 -
https://ibb.co/FzsSk3D -
https://ibb.co/WWJxCR2 -
https://ibb.co/pJvCzFg -
https://ibb.co/D5s84CC -
- I used my rig with GTX 1060 couple days after that I removed drivers with DDU and installed new GPU.
- Deleted everything that can interfere with gpu but nothing changed.
- Installed clean win10 and win11 and nothing changed.
- Updated BIOS but nothing changed.
- Turned off XMP nothing changed, put higher mhz nothing changed.
- Tried with 1080p monitor and 1440p monitor and both at the same time, nothing changed.
My rig:
CPU: Ryzen 7 5700X
OS: Windows 11 Pro
