Everything was fine a day ago, then today I suddenly started getting really bad performance on games. I got 40 fps on League of Legends and I'd get more on that with an Intel HD Graphics, so it doesn't really make sense.
After checking a few things, I realized that the gpu usage was really low. I checked if it was getting enough power supply, updated the drivers, even changed the cables that connect it to the power source and it's still the same.
I know the gpu usage shouldn't be maxed out all of the time, but it should be higher if I'm getting bad performance, especially on a game like League, in which I was getting 40 - 50 fps with close to 20% gpu usage. I've done some benchmarks and the usage is changing constantly, the higher it got was 66%
Quick update: I was searching for things that could be malfunctioning again and I found out that my cpu is running on 100°C without anything opened so I guess the problem is there
Would replace the thermal paste help? I have this cpu since 2014 and I don't remember doing it...
Gtx 1060 6gb
I7 4770
8Gb RAM
ASRock Z87M Pro4
Ocz 700W
Gtx 1060 6gb
I7 4770
8Gb RAM
ASRock Z87M Pro4
Ocz 700W
