I've been having way too slow upload speeds on my computer. I have 100Mb download speed and 10Mb upload speed, but my computer just has 2Mb upload speed, with sometimes not even reaching 1Mb. My computer is connected through an Ethernet cable. Last week my cousin was with me, he is a Network Technician, and so he tried a lot of things. He used the same Ethernet cable as my computer to test it on his laptop, which had 10 and even 12Mb upload speed. He also tried to share some data through the local network, and surprise surprise, it was at normal speed, not the 2Mb. I did uninstall all my VPN's (SoftEther VPN and Hamachi) and yet the same result, having 2Mb upload speed. I did also install Windows on a new SSD that I just got two days earlier, so I took advantage that it was with pretty much nothing on it and installed Windows on it and disconnected the main SSD and HDD, and the upload speed was the same, so I don't think it's a software problem. My cousin told me already the problem, he thinks my computer it's haunted lol. He didn't find the problem nor the solution.
Any advice? Should I just go ahead and change the motherboard or do something else?
Thanks in advance.
Edit (responding to Ralston18): PC SPECS:
Personal router: Huawei
Router in my bedroom (the one I'm currently using): TP-LINK AC1200
The tools I'm using to test my speed are https://www.speedtest.net/result/10282856366 and www.fast.com
Thanks in advance.
- Asus H310M-K Motherboard
- Processor Intel® Core™ i5-8400 CPU @ 2.80 GHz
- Video Card NVIDIA GeForce RTX 2060 Super OC Gigabyte Windforce
- RAM 16.0 GB HyperX DDR4 2400Mhz (2x8 GB)
- Operating System Microsoft Windows 10 Professional 64-bit
- 250 GB SSD
- 3 TB HDD 7.2K RPM
- PSU Gigabyte G750H 80+ Gold
- Tp-Link TG-3468 Gigabit adapter
