[SOLVED] Low upload speed
adyyy7
49
Hi there!
Thank you in advance for any helping ideea here.
I have motherboard asrock h81m-vg4 h81 2ddr3 2sata3 .
The problem is that the upload speed is 10-20mbps instead of over 500mbps on other devices i tested on same cable.
The network board is incorporated on mother board , so i think is MB foult for the low upload speed.
Also i get some weird restarts sometimes without any reason - also indicates MB problems.
What should i do?
Can i try first to buy a network board and if is the same problem buy a new MB? Is TP-Link TG-3468 ok?
If the problem persists can i buy a new MB with same sepcifications so i can use the same CPU and memories?
Thank you !
