G
Guest
Guest
Lemme give you my specs first:
IBM 60gb hdd
Athlon T-bird 1000
A7V motherboard
Geforce
256mb of ram
This morning before I left for class I started to defragment my D: drive. Which was the larger of the 2 drives I had partioned....was like 55gb or so. C: was 5gb. So I started it up and left. This was with normal windows 98 disk defragger too. Few hours later I come home and the monitor is black and there is a weird clicking noise. I couldnt get the monitor to kick back in and was basically screwed so I had to reset the computer. Since then it doesnt find my hdd during bootup. And the clicking noise is still there. I had it running in the ata-100 port also. And I tried putting it into a normal ide port but that didnt work either. Can a bad defrag mess up a harddrive like this?Please dont tell me all my data is gone 🙁
Can someone help me out here? Thanks in advance.
IBM 60gb hdd
Athlon T-bird 1000
A7V motherboard
Geforce
256mb of ram
