Manli GF4TI4200 heatsink and fan
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
I have had this card for a while working just fine
but the fan just died out.
Does anyone know which replacement I can put on it,
meaning heatsink and fan.
Can't ask Manli as I can't even reach their web site.
Than you
Chris
2,048
"Rica" <ricardo@nospam.net> wrote in message
news:42e5423c$0$308$7a628cd7@news.club-internet.fr...
> Than you
I know that Vantec did a replacement copper HSF fan assembly for the GF4Ti
line. I know because I have one in front of me! (unfortunately already with
someone's name on it). Its called the Vantec ICEBERQ4 Pro and fits
4200/4200-8x/4400/4600/4800 and 5600U. Runs from a molex connector and has
blue LED. For blue LED freaks. Do a search on eBay perhaps?
HTH
Chris
G
Guest
Guest
>>Than you
> HTH
> Chris
Thank u, I'll look into that
G
Guest
Guest
>>> Than you
>> GF4Ti line. I know because I have one in front of me! (unfortunately
>> already with someone's name on it). Its called the Vantec ICEBERQ4
>> Pro and fits 4200/4200-8x/4400/4600/4800 and 5600U. Runs from a molex
>> connector and has blue LED. For blue LED freaks. Do a search on eBay
>> perhaps?
>> HTH
>> Chris
Looked into it and was about to buy one but
the problem is that it takes two pci slots
and I need the second one for my SB Live.
Is there something else that would fit ?
Thank u
Chris
2,048
news:42e5fdc1$0$306$7a628cd7@news.club-internet.fr...
> Thank u
It certanly DOES NOT take up a second PCI slot. It is meant as a
replacement for the original HSF assembly. If your GF4Ti doesnt take up an
extra slot (and I don't believe any of them did) then removing your existing
HSF and fitting the vantec wont take up any extra room. You must have been
looking at some sort of heat pipe assembly!
This is one on ebay.co.uk
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=80151&item=6776129954&rd=1&ssPageName=WD1V
HTH some more!
Chris
G
Guest
Guest
>>Thank u
> HTH some more!
> Chris
Thank you
Asked the girl if she could send me one to France as she ships only
to UK.
If not, will look for another one.
