Question Maximum devices per ARGB/RGB header
Aug 18, 2023
Saying that I will buy an argb hub (8ports)
Is it safe to connect that many devices to one header? will my motherboard be damaged?
What I want to get is an AIO (3ports)
Lian LI strimer argb cables (2more)
Let's say 2fans (2ports)
And a cooler master rgb GPU holder (1port)
Is that too much amperage
Thanks in advance
Update your post to include full system hardware specs and OS information.
Include PSU: make, model, wattage, age, condition (original to build, new, refurbished, used)?
Disk drive(s): make, model, capacity, how full?
Total the amperages for all connected devices.
If any device has a range of amperages use the high end value.
Post the device list with the amperage for each device.
Objective being to quantify "too much" using actual amperage values.
