Question Mb520 ARGB And The Msi Tomahawk max
Oct 21, 2020
17
I just got the mb520 argb in the mail today and I plan on getting the msi tomahawk max. Will the argb fans work with the tomahawk max because it has a Argb fan splitter
Just plug the things in that can fit with each other. It isn't really rocket science. If they fit, then they probably are supposed to plug in there. I normally wouldn't say this, but its just rgb and fans. Do what fits. If you mean that you have 3 more fans, then you will need to plug the same things in to the same ports.
Thanks if it doesn't work ill come back here
