MCE 2005 Remote Control Issues
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I recently loaded on MCE 2005 onto my computer. I couldn't be happier with
this OS, except i'm having a problem with the remote control. I am using the
Hauppauge 150 PVR tuner card and remote. Only a few buttons on the remote
work, Volume, Record, Play, Pause, Fast Forward, Replay. Nothing else does,
i was wondering if there were any updates i needed to download from Microsoft
to make it compatible. Thanks for your help
For MCE, you need to be using the MCE Remote. The Hauppauge remote is not
supported, and will yield either non-working or unexpected results.
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
http://mvp.support.microsoft.com/default.aspx
"Kohldog101" <Kohldog101@msn.com> wrote in message
news:5BE52F7D-948B-4108-A7E3-48A2D4FB7806@microsoft.com...
> the
> does,
> Microsoft
