Question Mce and turbo boost
SnowMN
41
If mobo z390 aorus master gigabt and i7 9700k and power in windows on balanced what would push cpu in clocking always 4.7 ghz even idle on all cores,would it be mce enabled?also what would be the difference between auto and enabled on both mce and turbo boost
Thanks in advance
Turbo boost sets whether to enable/disable turbo.
Enhanced Multi-Core Performance runs all cores @ turbo speed automatically even at idle. Default setting is auto which turns it on.
Windows power settings do not affect this type of performance.
I've had MCE on (Asus Z270/7700K) for 2 years, and , my CPU still idles at 800 MHz, and, when turboing under load then goes to max turbo on all cores....
MCE (at least with Asus' implementation) does NOT cause a CPU to sit at max turbo all day long. eliminating idle....
