Hello, I'm creating this form post today because I have encountered a complexing issue with my computer system. Additionally, the problem is with my systems mechanical hard drives and its transferring and reading speeds or read/write speeds. I have a total of six mechanical hard drives in my system and they were all various speeds, however, the one common factor they do share is that there all 6 Gb/s. Moreover, these mechanical hard drives or for gaming and/or storage, so I do not use these drives for my main operating system. Furthermore, the drive that I use for my main operating system is a M.2, which is a Samsung Evo 850. The issue is my transfer speeds are not being utilized as intended. For example, when I transfer a file let's say a video file from the 850 Evo to one of my mechanical drives my transfer rates start off at about 550 Mb/s and dropped to 5 to 9 Mb/s. Interestingly enough however, when I am transferring a file and it drops to these amounts and then I go and transfer another file either to the same hard drive or to another hard drive from the Evo 850 my transfer rate increases briefly to 1 Gb/s. Thusly, while the second file is being transferred there will be fluctuation in transferring rates, which is to be expected, however, while I'm transferring the second file at the same time as the first file, my speeds will fluctuate from 5 Mb/s to over 1 Gb/s. Additionally,if I'm only transferring one file at a time I never see transfer rates above 80 Mb/s. Furthermore, when I transfer a file from the hard drive back to the 850 Evo does it's a quick that there is no transfer rate even being presented.nevertheless, my transfer from mechanical hard drive to mechanical hard drive I get a transfer rate between 3 to 6 Gb/s. I realize that there is a bottleneck somewhere I'm not exactly sure where the bottleneck would be located.moreover, I have checked the computer for viruses and the like, and nothing is sticking out as far as red flags. Additionally, check my network for weak points and have found none. Furthermore, this problem persisted on my older motherboard as well which was a as rock X299 killer SLI/AC. I'm doubtful that it is the motherboard, I'm leaning more toward the hard drives themselves or maybe the front side bus. additionally, I will tell you that the GPU is installed in the second 16 express slot instead of first, and this is because of clearance issues with the air cooler.nevertheless, this issue has presented itself basically from day one, however, the problem has gotten worse over the past two months, and yes this was an issue before I delidded the CPU.additionally, my CPU temperatures at hundred percent utilization is around 74°C and it idle my temperature for the CPU is 23 or 24°C after warming up. also, my CPU is rated at 2.8 GHz after the delid I achieve 4.6 GHz boost. And yes these are automatic clocks nothing manually set. before the delidding process my temperatures at 100% yield was 85 to 96 degrees Celsius And my clock speeds at max was 3.6 GHz a second. Also,I will provide my system specifications below and the dates of purchaseof all major components.lastly,I have tried to be as thorough as possible explaining the situation and my system build, I'll try to provide any more information if I can. In addition I've captured to screen images to show the difference in transfer rate.
Motherboard X299 asus addition 30 ( date 12/21/2019
CPU Intel 7960 X (delidded) ( date 4/5/2017)
memory 64 Gb DDR 4 crucial ballistic sport 2400 MHz ( date 9/18/2014)
graphics processing unit aorus 2080ti xtreme waterforce wb ( Date 11/28/2019)
CPU cooler noctua d15
optical drive LG WH16NS40 ( flashed to accommodate 4K ripping support)
deliding cpu Materials used.
crc 18411 Urethane seal coat coating clear ( used this instead of nail polish )
Thermal Grizzly Conductonaut Liquid Metal
JB Weld 31314 High Temperature rtv Silicone gasket maker and sealant
Noctura Nt - H1 Pro Grade Thermal Compound
Rockit 99 Delid & Relid Lga 2066
Gpu Cooling
Alpha cool D5 vpp655 (Non Pwm)
Radiator Koolance 140 MM 30 Fpi
Fans 2, 140 mm Noctura Nf-a14 ippc-3000 Pwm ( for Radiator Push/pull )
compression Fittings koolance 6mm/10mm.
Fluid Koolance LIQ-702Bu-B
Case
cases fans 6 120 mm Noctura Nf-a12 ippc-3000 Pwm
Hdd's
Western digital Green 4Tb WB40EZRX (rpm Unknown ) ( Date 01/20/2015 ) ( Storage )
Western Digital Black 4Tb WD4001FAEX ( 7200 RPM) ( Date 01/12/2013 ) ( Storage )
Western Digital Green 3 Tb WD30EZRX (rpm Unknown ) ( Date 03/23/2013 ) ( Storage )
Seagate 4 Tb 5900 Rpm ( Model st4000dm000) (Date 11/2013) ( Storage )
Seagate 8 Tb 5900 Rpm ( Model st8000as0002) (Date 7/2015) ( Storage )
Toshiba 5Tb (7200 RPM ) (Date Unkown Bought Around 2012 to 2013) ( game drive )
psu
Evga Super Nova 1300 Watt Gold (date 3/24/2014)
Gpu Cooling
Case
Hdd's
psu
