Archived from groups: microsoft.public.windowsxp.games (
More info?)
Hi Bill,
It could be either the mouse, it's driver, or most likely the
surface you're using the mouse on. Try a non reflective
surface and it should hopefully resolve that issue for you.
Cheers, Windows XP MVP Shell / User
Jimmy S.
http://mvp.support.microsoft.com
Visit my MSN Zone.com and Gaming Help Site:
http://mvps.org/nibblesnbits
MS Games Help and Support Center:
http://support.microsoft.com/?pr=gms
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
"Bill P" <wmp@nospamfor26for.fsnet.co.uk> wrote in message news:deq2a8$ruh$1@news8.svr.pol.co.uk...
| Thanks for the quick reply Jimmy.
| I have uninstalled CloneCD and the game is up and running now. One problem
| that I have is that the mouse movement is all over the place. I have tried
| adjusting sensitivity and smoothness but it is still not very satisfactory.
| I have a cordless optical HP mouse and I was wondering if that could be the
| problem .
| Regards
| Bill
| "Jimmy S." <nosp@m.pls> wrote in message
| news:O3ve6exqFHA.3660@TK2MSFTNGP15.phx.gbl...
| > Hi Bill,
| > If you indeed have any CD Emulation software, running remove
| > it. Many times NERO CD Burning Software is the culprit.
| > Before we begin troubleshooting the issue, if you have more than one
| > DISC player (CD/DVD/CDRW/DVDR/ETC) in your system, I've seen
| > this type of problem resolved by simply using the other DISC player.
| > Here are some other more involved solutions which have worked:
| > 1. You might be affected by problems similar to the Insert CD error.
| > - Try the advice and DL at:
http://support.microsoft.com/?kbid=228985
| > Another trick that I found sometimes works is to make the limited
| > account an
| > administrator account and run that game once. This should create the
| > registry
| > settings and permissions for that user to be able to properly run the
| > game.
| > 2. Kazaa or Kazaa light is installed on your system.
| > - Uninstall the game(s) and Kazaa, and reinstall from original CD.
| > 3. Multiple CD drives on your system including Virtual CD drives.
| > - Disconnect all but the main CD drive and try the game. You
| > might have an older drive, or a CD Writer which is incompatible
| > with the Safe Disk copy protection on the CD. (Contact Vendor).
| > 4. Your antivirus or application firewall might be conflicting with it.
| > - Disable the software temporarily.
| > 5. There might be a patch available for your game to correct the issue.
| > - Try www.avault.com/pcrl/patches_list.asp?letter=a/ or the game's
| > site.
| > 6. To see if it's a software conflict: Temporarily disable Startup
| > programs one at a time, starting with Firewall, Antivirus, and ad
| > blockers using this utility:
http://www.mlin.net/StartupCPL.shtml
| > or this method:
http://www.pacs-portal.co.uk/startup_content.php
| > 7. If you created other drive letters on your system by installing
| > another drive,
| > creating partitions or virtual drives you may need to change the CD
| > back
| > to the same drive letter it was originally. Usually the CD uses
| > the letter D:
| > - Click Start / Run / type: diskmgmt.msc < to access the tool to
| > change it.
| > Lastly, boot up your system, turn on your XP Internet Firewall, plug
| > back
| > into your Internet connection and install all Critical and Recommended
| > updates
| > from:
http://windowsupdate.microsoft.com one at a time.
| > Jimmy S.
| > Game FAQs:
;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
| > Visit my Zone.com / Gaming Helpsite:
http://nibblesnbits.tk or Call /
| > Contact
| > MS Support at:
http://support.microsoft.com/default.aspx?scid=sz;en-us;top
| > rights.
| > news:depo4r$3oi$1@newsg3.svr.pol.co.uk...
| > | Hi
| > | I have just installed MoH Pacific Assault.
| > | When I try to play the game I get the following popup
| > | "Cannot locate the DVD-ROM
| > | CD/DVD emulation software has been detected. Please disable all CD/DVD
| > | emulation software and restart game"
| > | Any help would be appreciated. Please let me know if further info is
| > | required.
| > | Regards
| > | Bill
