Question Memory and Upgrade Help.
May 4, 2023
Hello everyone I have a quick question. I am looking to upgrade my current Pc - Here are the specs -
Device name DESKTOP
Processor Intel(R) Core(TM) i3-4150 CPU @ 3.50GHz 3.50 GHz
Installed RAM 8.00 GB
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
GPU - GTX 1050 ti
700w power supply
I mainly use the Pc for producing music and editing video in premire pro [ premire pro lags alot ] and some mid level gaming.
My question 1. Is it worth upgrading my Ram to 32Gb or is it better to just get a ryzen 5 or i5 or i7 that has more slots for ram due to the i3 only having 2 slots for Ram ?
Can any one recommend a better set up if posible that is budget friendly ?
Thank You For Reading My post.
I would recommend going for a whole new system. That Intel platform is so old that it isn't even worth upgrading your processor to an i7. I would recommend Ryzen 5 or 7 with 16GB of RAM. The more RAM you can afford the better. If you don't intend on gaming then there is no problem carrying over that graphics card either.
Reactions: SpectrumAudio
Thanks for the comment if i went with a ryzen 5 or 7 what would be a decent budget friendly GPU ?
Device name DESKTOP
GPU - GTX 1050 ti
700w power supply
Depends on how high up the perf ladder you want to go and how fat your wallet is.
For around a 100 bucks you could go to 16GB of ram and a ssd for storage.
See if that fits.
See if that fits.
Thanks for the comment I was thinking if i where to upgrade this i3 i would go with 2 - 16gb sticks.
