ok guys this is the first time i overclocked and i set all the settings that needed to be set to disable and enable. i have the fsb at 340 and the multiplier 9.5 so on my E7200 @ 3.2Ghz at Rated FSB 1363.8Mhz.
but my problem is that i want my memory at 1:1 but right now its at 4:5
therefore the DRAM frequency is at 426.2MHz and i have 4096MBytes and the first stick of ram is at PC2-1200(72 MHz) but my second one is at PC2-6400 (400MHZ) why???????? is that supposed to happen when u change the fsb and if not how can i change the divider back to it??
what should i do!!!????
my specs are:
E7200 @ 3.20GHz
Asus P5Q-Pro
Corsair 4096MBytes at PC2-6400 DDR2-800 5-5-5-18
my specs are:
E7200 @ 3.20GHz
Asus P5Q-Pro
