I just randomly started having problems with this game out of the blue with no explanation or cause. The game has been on the most recent update since I started playing it again-- I never got around to finishing it because of a huge library of other games I'd been going through. I'd been playing it fine for days with 60fps+ at 1440p on an RX 480 and a FX-8350 @4.2Ghz. One day though, I booted up the game from sleep mode (which I always had) and noticed a pretty horrendous controller lag (using wireless Xbox One adapter on Win7) which were causing the camera and other inputs to go haywire! I'm also now getting continuous micro-stutters every 2-3 seconds which make aiming and other controls downright impossible-- in turn, making the game unplayable.
This has been absolutely driving me crazy for like a month now; even more so that it happened right out of the blue. I've done everything in my power to fix it with no avail.....DDU'd drivers and reinstalled, lowered settings, ran memory and BIOS check....you name it nothing has worked. I even just recently upgraded to a GTX 1080 Ti (not because of this problem, I had my pre-order down for a while for an upgrade) and this game still has this random problem. I've checked other games and they all run fine-- it seems to only be affecting this game....and again, it happened just randomly one night and continues to happen right out of the blue when it used to run perfectly. So after the GPU upgrade, I think I've concluded that it is NOT a GPU problem and must be something else. Does anyone know what could have caused this problem?? Is my RAM doing something in particular to this game? I've run Malwarebytes and a Norton full system and nothing out of the ordinary has been found. Any help would greatly be appreciated, thanx.
Specs:
Gigabyte FX990-UD3
FX-8350 @ 4.2Ghz
GTX 1080 Ti
16GB DDR3 RAM 1333mhz
Lightning 1000W
Specs:
Gigabyte FX990-UD3
FX-8350 @ 4.2Ghz
GTX 1080 Ti
Lightning 1000W
