dolce_ardore
[citation][nom]Emperus[/nom]Correct me if i am wrong but rectifiers as i understand them are basically used for ac to dc conversion.. I can understand using diode(s) on a reverse current (dc line) protection role as diodes block dc.. But this very nature would make them unsuitable to be used in forward dc current paths.. And batteries do produce dc current..[/citation]
"A diode bridge is an arrangement of four diodes in a bridge configuration that provides the same polarity of output for either polarity of input."
http://en.wikipedia.org/wiki/Diode_bridge
The problem with using a brige for each battery cell would be, as others have pointed out, that the current from each battery must pass through two diodes, with the associated voltage drop. However, this could be built into the design of the circuit, e.g., a nominal 3v circuit might use three batteries in series instead of two. I suspect though that Microsoft has come up with a more innovative solution.
