Question Microsoft Edge problem with signing in ?
zolydream
32
Hello everyone,
i have a problem with signing in on Microsoft Edge on my PC.
I click to the sign in tab, there is saved my Outlook email address and there appears only one tab "Send Code".
i'm logged in to my Outlook email but I never get any code. I also checked the junk folder but nothing.
My internet works fine and I can receive emails on all my other email adresses.
The problem is that I don't have any other option to sign in to Edge, it's just this "send code" option.
What can I do? Any help would be appreciated, many thanks !
What Windows OS is installed?
What version of Outlook (Classic or New) are you using?
My thought is that Microsoft Edge is defaulting to some web page requiring you to enter a confirmation code in order to login or otherwise access that web page.
And that confirmation code is being sent to some other email account - not one of yours.
Take some screenshots and post the screenshots here via imgur (www.imgur.com > green "New post" icon).
More information needed.
Reactions: zolydream
Hello, first of all thanks for your answer, i have windows 10 installed, i use chrome browser for my outlook email account ( i logged in also from my phone and there is no code ). I send you here 3 screenshots to see what's all about...
View: https://imgur.com/dmUEvNN
View: https://imgur.com/GDLAljP
Mod Edit: remove the image with email address.
why would it need a code? account recovery? it wouldn't try to send a code to itself.
try open edge inprivate mode?
Because i have saved bookmarks and passwords on edge when i was logged in with my outlook account. Somehow i signed out and now i can't sign back to access the pages and passwords are saved there. I can login to my microsoft account with other browser (for example chrome) but i need EDGE to access what i wrote. I hope you understand me well, my english is not the best..... Btw. i tryed private mode but as i said i need my saved things (sync).
@ zolydream
Question - only to ensure that there is not some confusion....
Are you using the Outlook email app and/or the outlook mail server?
As above (Post #3) you should not post or show your email address. Mask your email addess.
For example: my email address is provided by Xfinity (Comcast) via a "XXXXX@comcast.net".
[Note: for the record - Xfinity/Comcast no longer permits/accepts new _______@comcast.net email addresses.
Inactive comcast.net addresses are being purged.]
Microsoft uses XXXXX @outlook.com for their mail servers.
(Apple uses @icloud.com Google is @gmail.com.
The imgur images show that you are using New Outlook (vs Classic) - the app.
Also: If you open your email app you should still be able to open Edge in another window in order to access what you wrote.
that why I don't like everything connected in windows. what could go wrong.
punkncat were you able to login?
I was away for a much needed vacation with some friends. For some reason I cannot seem to recall exactly what I did, I am thinking it was a complete reinstall and a change of some options.
I discovered this weekend while helping a friend with a laptop that Edge will not allow you to log in without using Windows Hello, and/or if you try to use the local only account option. Very slowly they are closing all the doors. As a result of that I have downloaded and am trying out Brave browser. If Linux would allow integration into some work related apps/sites that are required I would use that instead. As others have also warned about, every time I try to log in to Amazon it keeps asking for my Windows Hello PIN. So far cancelling out is working, but cannot imagine that will be long.
MS is putting its own nail in the coffin with "features" like this.
