Hey.
So I Recently Replaced My Thermal paste on my CPU (Corsair Tm30) and When I tried to turn My PC on the Fans would turn on and start spinning but there would be no signal to the monitor. With the help of another lad on a pc forum, I got the issue fixed, I just had to clean thermal paste off of the CPU pins with a toothbrush and some Iso alcohol . Now my PC turns on but in games I can see microstutting happen quite frequently, this did not happen before replacing thermal paste and fixing my cpu. The stutters are noticeable enough to mess up trickstabs and its pretty annoying. A note is that I was not able to fully screw in the CPU cooler (AMD Wraith) Due to the MOBO bracket having the screw holes worn out and unable to screw 2 of the cpu screws. I was still able to screw in 2 however and temps are fine. Another note is that I was reslotting the ram during troubleshooting and I bended the ram slot out of place for half a second but It still works and both my 4gb sticks show up in task manager. Another note is that I enabled Override mode in BIOs to try help the issue but it didnt do much. Anyone know whats up and will a quick fix like buying a gpu like a 1050 help? I dont do much heavy gaming on this pc , I play tf2 and fortnite and CSGO.
Specs: CPU; ryzen 5 3400g
Ram: two 4 gig sticks of ballistix
Mobo: Msi a320 pro max
Psu:Corsair 650 watt non modular psu (overkill ik)
