Is it better to buy a 3090 FE with fans running at 100% for the last 4 or 5 months, or to buy a 3080Ti which was only gamed on weekend to weekend if they are the same price?
Used marketplace is pretty much my only option because new versions of each model are close to twice the cost if not more.
I will be mainly using the card for 1440p gaming, streaming and editing/rendering videos from time to time.
I asked for the 3090 FE's thermals:
Memory temps fluctuate between 86 and 95 and the gpu itself is at 55-65 and it still is using the stock thermal pads and compound. What I'm concerned about is he always runs the fans at 100% and I am worried about if it is harmful or not.
