Hi guys, I have been having this weird issue with my computer ever since i got it, it booted up fine, no errors, i used windows 7 to start it up, set it up properly at my home, and installed windows 8 (which was the latest windows available at the time), just before windows 10 came out and it would just freeze on load or after some random time, either on startup, installing a program, playing games, watching a video, any literal task would make it freeze, i then tried using different OS's like max osx, ubuntu, and windows 10 which had just come out, and no difference......then i installed windows 7 again, and it worked fine!? so i started using windows 7 and its been fine ever since, i want to upgrade the OS now, maybe use windows 10, and the same issue occurs, it would freeze at random times.
NOTE: i have used different I/O, different GPU's(from amd), different ram modules, different coolers, different power supplies, and the case would stay the same. And i had posted about this before and the community said it was my PSU, i did change it to a lower rated PSU and used a different card, it just took longer to freeze at first, then it just behaved the same.
I'm using an asus m5a99x evo r2.0 mobo, the core is AMD FX-6300 black edition, its watercooled now, cant remember what the cooler is, 16GB Kingston ram(if i haven't changed the ram), a AMD Sapphire radeon HD6750 GPU, using an SSD now for the OS, and have 3other harddisks for storage(some are with the old windows 8 installation and had files i needed, and felt lazy to shift the files over to another disk).
Any solutions?
Any solutions?
