I'm starting to put together the component list for my new PC, and to start with I'm looking at the motherboard.
To start with, my CPU of choice will be an i7.
My main concern is going to be slot space on the board, as my current GPU solution is to take my existing double-height XFX HD5770 and add in a second, single-slot HD5770.
Right now I have no plans on overclocking any components, if that has any bearing on my choice.
I've had a good experience with Asus MoBos in the past so if there's an Asus that fits my needs, then that'd likely be my first preference, but I'm open to all good suggestions.
Budget for the MoBo is around $200.
Thanks for taking your time to read & hopefully answer my query!
Neil.
Neil.
