[SOLVED] Molex connector problem ?
Page 7 - Seeking answers? Join the Tom's Hardware community: where nearly two million members share solutions and discuss the latest tech.
ferguson1951
202
Hello everybody.
I am writing from Italy.
I have an ATX PSU with various output cables including a 4-pin Molex which I think is for the mobo power supply.
But my micro ATX mobo has an 8-pin connector.
How do I go about solving this problem ?
Your help will be much appreciated.
Thanks a lot and best regards
Mobo: Asus Prime B364m k
PSU: Delta Electronics 350 w GPS-350EB-200 B
ram: Samsung DDR4 4Gb.
GPU PCIE card : (arriving) ASUS EN 8400 GS SCHEDA GRAFICA VIDEO SILENT PCI EXPRESS 512 MB GPU GRAPHICS CARD
CPU: Intel i5 8500
Case: HP ProDesk 400 G3 MT
OK, PWR LED AND PWR SWITCH are fitted and they work. Now let's concentrate on the CHANNEL FAN.
The mobo description has 4 pins: from left to right ...+5v...CHA FAN IN...CHA FAN PWR and GROUND.
How do I fit my 3-pin fan connector. Thanks a lot
There is only a single way to fit 3pin fan on 4pin header.
Note - you have to switch fan regulation mode from PWM to linear voltage (DC mode) in BIOS.
Or else it will not be regulated properly.
OK, great blokes, the die is cast !!! I now think spending 15 days naked at the North Pole should be easier, but I made it. Thanks to you both, SID and Sky Rising. I think I owe you two tickets for the Ascot Race. Or a week's free fish & chips and beer.
Anyway, without you both I would have never made it. By the way, the back fan works without having to touch the Bios. Thanks again. God save the King!
With 350 quid you can build one like this
View: https://imgur.com/hd6KKb3
View: https://imgur.com/54XvgGY
View: https://imgur.com/8yqSAfC
Cables can be routed behind motherboard tray - to look more tidy.
That is purpose for all those holes in motherboard tray.
SSD can also be installed behind motherboard.
Use screws that came with pc case.
3pin fan will work without changing BIOS settings.
It will not get regulated properly though. It will spin at constant speed all the time.
