I assume you mean that the flicker happens only as the change-over is happening from AC to battery, or the other way. Other than at those times there is no flicker. Right?
For some types of UPS this is normal. The simpler design of UPS simply feeds power from the AC supply on the wall to your computer, plus uses AC from the wall to keep its battery charged. When the AC supply fails, the monitoring circuits in the UPS switch over to converting power from the battery to AC that it can send to the computer. It also must disconnect the link from wall outlet to computer load, so that there are not TWO sources of AC power connected to the computer at the same time. That change of operation takes a second or less, and hence there is a brief...
