Question Monitor goes into sleep mode, PC fans ramp up to 100%, audio normal for a few seconds, PC bricked ?
GroundZeros
19
Hi, 3 years ago i made the same post to the GPU subforum and didnt get a response, im going to try my luck again and potentially find a solution.
I mostly boiled it down to either a GPU or a motherboard issue altough im still not sure
Ive had this issue for around 3 years and mostly coped with it by suverely reducing game graphics and general PC load, it still happens but much less so.
MBD: ASRock Z68 Pro3
GPU: RX 580 8GB
CPU: i5-3470 4C 3.3GHZ
RAM: 8GB DDR3
The trigger seems to be high load, specifically lots of particle effects, even tough framerates and temperatures are stable.
So basically, when it happens the screen goes instantly black, followed by the message that the monitor goes into "power saving mode", fans kick up to the max and audio of the game still works for a few seconds before cutting out as well with the PC being affectively bricked as im forced to do a hard reset, then it boots up normally
also worth noting, during the boot theres also the return of the high speed fans for a few seconds before going back to normal
so far, ive had this happen in basically every game ive played
even tough i said temperatures are normal, it occours more often in the summer then the winter
ive mostly taken preventive measures when i relise that theres higher loads, such as limiting framerates and reducing visuals, but still not enough
there is event noted in event viewer aside the critical kernel power upon a hard reset
in addition to this, the bios often goes to the legacy boot screen (the black and white boot thingy) as opposed by the asrock logo and the system runs check disc everytime for the last few months
any ideas? fixes? tips?
brand and model of the psu?
what is the exact cpu/gpu temp?
thermaltake toughpower grand 750W​
CPU hovers around 60-68c​
GPU 83-85c (~78c after tuned edit*)​
at full load with Heavyload​
its also the GPU fans that go 100% when it happens​
slight little edit, ive decided to bring down the clocks and undervolt the card, i will post back if its fixed​
so it appears after bringing down the speed and voltage it doesnt happen, at one point it changed back to default settings for some reason and it happened again, but with the custom clocks and changes it seems to have stopped happening
another edit 😀
seems the moment i applied the different clocks and voltage (first time and after it reset) that the display appears to flicker at random every few minutes, and just later today a horizontal line of blue pixels has appeared on the monitor permanently so whatever i changed on the GPU is now affecting the monitor as well
Sounds like a PSU concern to be honest. All your drivers up to date? You ever removed and re-seated the card?
drivers are up to date, i havent reseated the card
as said earlier, when slowing down clocks and voltage it goes away, with the monitor flicker coming into effect 😀
not sure if theres anything to do except change monitor, this is a tv monitor thats atleast 16 years old
I had a similar issue with my old rig and once I swapped out my PSU, the issue stopped. Based on my anecdotal experience, I'd definitely recommend starting there.
