I'm not sure if this is the right section for this, or if the system section is more applicable.
A few months ago my PC started running into an issue where the monitor would occasionally cut to black and audio would loop, or continue to play as normal. This would require a forced restart. Eventually this issue resulted in my primary hard drive going bad. I turned the computer on after it went black one day and it just said no bootable device was found. I wound up building basically a whole new PC. The parts I carried over were a GTX 980 FTW Edition, my 16GB or Ripjaw RAM, and my monitor, an old ASUS that had developed a bit of burn in. I also took with me two mechanical backup hard drives.
After setting up the new PC, this issue happened a couple times, so I figured maybe the monitor was going and went ahead and replaced it with a new Westinghouse monitor. Nothing fancy, just what I could afford at a decent resolution. I stopped having the issue until last night, after reinstalling Oculus software for the first time on the new PC. I also installed Voicemod and Morphvox because I wanted to screw around in VRChat. Morphvox just looked kinda fishy to me when launching it, even though it's apparently legit and safe software. I uninstalled it and went with Voicemod. About ten minutes into a session of VRChat, the screen went black along with my VR headset, and the last few seconds of audio in the game looped. I restarted and tried again and was able to stay in just fine for a couple hours.
I uninstalled Voicemod and Oculus afterward, thinking maybe something was screwy. After using my PC today and speaking to a friend over Steam, my monitor began to periodically black out, just for a couple seconds before returning to normal. It did this twice in the span of an hour. I checked the event viewer and didn't see anything failing. I did see a lot of security logs for audits and logons, but I don't know if that's normal or not. Those were the only things to really occur around that time. I've since restored my PC to the day before I messed with all this Oculus stuff, and so far so good, but I'm wondering what the issue might be? My anxiety is through the roof after having blown over a grand putting a new PC together and I really don't want this one falling victim to the same issue, whatever it is...
I'm running a home edition of Windows 10, i'm not sure what other information is pertinent for this but I can provide anything else if asked.
edit: I've also tried unplugging the monitor from the GPU and running an HMDI cable to the port on the motherboard, an MSI MAG z490 Tomahawk, but when I do this while the computer is on, it doesn't regain a signal through the mobo. It will get a signal back if I reconnect it to the GPU. Not sure if that's normal.
Components are:
CPU: Intel(R) Core(TM) i5-10600K CPU @ 4.10GHz 4.10 GHz
Mobo: MSI MAG z490 Tomahawk
SSD: Samsung 870 EVO 1TB
RAM: Gskill Ripjaw 16gb
GPU: EVGA GTX980 FTW Edition
Case: Pure Base 500DX Mid tower ATX
Components are:
