The problem:
Sometimes when I start my computer it will be in a lower resolution 1200x800(approximately). When I go into my control panel that is the max resolution even tho is should be 1650x1050. It also says that the display is "display device on: HDMI". I can change this to VW225 if I plug and unplug my HDMI cable and then it go to my normal resolution. How do I force it to always be on VW225 or some other way to fix this. The generic PhP monitor is just black but I know its there.
Some context:
This is not the first time this is happening I was happening before and I think my workaround was setting a custom resolution for the display device on: HDMI. This started happening again after I updated my graphics driver with a clean install.
Thank for replying.
Some context:
Thank for replying.
