I bought the AMD athlon x4 860k processor for my msi fm2-a78M-E35 motherboard.
You can see my full computer on this DUTCH site:
http://gamepc.nl/game-pc-budget?tab=configuratie#samenstellen
it is all on the default only change i made to this computer is that i have a 750 ti gaming graphics card in here aswell.
So this is the problem: i installed my cpu with extreme care, using a anti static wristband.
I installed with the golden corner on the other golden corner.
No pressure, dropped in, everything correct.
Put on the stock cooler.
I then tryed to turn my computer on:
what works:
The fans in my computer turn on, even the one on my cpu.
the lights in my case turned on.
The light indicating that the computer is buzy((ram usage?) not sure) turns on shortly.
What doesn't work:
The screen stays in the sleeping mode.
upon giving the screen power it does show the logo meaning it does work.
When the computer is turned on however it stays in sleeping mode (black screen orange light on the button.)
I have a mouse and keyboard with lights in it.
these do not turn on.
The mouse seems to work however, the red lazer on the bottom does light up.
I do have the old cpu, and i can put this back in again, but it's late now, i wont do that right now.
So what is wrong? did i miss a step?
I will be actively looking at this post, meaning if you react within a short time i will be able to respond.
what works:
What doesn't work:
