About 2 months ago I started experiencing pretty bad packet loss, on and off every few hours. 2-8 hours of stability, 2-8 hours of ~2% packet loss peaking in and out, repeat. About 2-3 weeks ago instant jitter also started becoming an issue, peaking out around 100ms.
In the two months since things started I've probably had 10-15 ISP technicians out here. They changed the entire household's ethernet cables, they changed the router, they've changed the line our house is running to, something about some booster box on the back of the house. They've checked the external running lines in the neighborhood (one of the technicians literally just drove around for 2 hours..) and not one of them can figure out what the issue is.
The issue isn't limited to one device, it affects every device in the house, whether wired into the router directly or through wifi, it doesn't matter. I compete in competitive gaming tournaments and do twitch streaming for a living, so I literally haven't been able to work for 2 months... Please if anyone has any ideas, dear god help me, I need to pay rent...
WHILE CONNECTED to a VPN, I can get readings on our network state through software called StarTrinity Continuous Speed Test, this is what it looks like when things are acting up:
WHILE NOT CONNECTED to a VPN, it can't even seem to download/upload the full desired amount, and therefore refuses to output packet/jitter data???
*** Notice how in Screenshot1 I tried 1up/1down, and in Screenshot2 I tried 2up/2down. The missing 300kbps chunk persists regardless of what speeds I attempt.
***Note that VPN/no VPN has 0 bearing on the actual quality of the network, it's the same regardless, I simply thought this anomaly might be a clue to the issue, so I threw it in.
Additional Notes:
-Speeds are virtually never an issue, just the Packet Loss / Instant Jitter.
-Every time the techs show up, they check the equipment, start to suggest everything looks fine on their end, then notice that "the system has restarted several hundred times." (per day? per week? idk)
-One tech said they checked some access point that our house, as well as 4-5 neighbors are connected to (the power lines out back?) and they said every neighbor's connection looked good, while ours didn't.
-The last tech said he ran our house to "a different line"? even though he wasn't necessarily supposed to, it didn't change anything.
-We're stuck in a Comcast monopoly zone pretty much... So our ISP is comcast/xfinity.
-We have a 500mbps plan.
If you have any questions that have even the slightest chance to lead to a solution, please do ask. Thank you for your time.
Additional Notes:
