I have an Asrock H110 Pro BTC + motherboard. I have a server power supply with a breakout board that has 16 PCie (6 pin) ports and one 4 pin Molex. I'm trying to establish the required power connections for the motherboard and CPU.
For the motherboard - I'm using a 6 pin to 24 pin Cable from amazon. 6 pin connects to the PSU, the other end connects to the 24 pin on the motherboard. This doesn't look right and I'm wondering if there are other options to make this work besides ordering a new breakout board for the power supply.
For the CPU power (8 pin) to PSU (6 pin) I'm suing the following cable. This looks right but asking for confirmation from someone that this application makes sense to them. You'd think that a standard PCIE riser cable (6 pin to 6 + pin) would work but apparently the 8 pin on the CPU connector is different.
Lastly - For the SATA power connector i'm using the following cable - 4 pin from PSU to SATA power connection to my SSD. Does this look correct?
Thanks in advance for any help. I would send pictures of motherboard and PSU.....but that seems to be an issue in this forum.
Kelly
Kelly
