Motherboard for Ryzen 5 1600
TomS_
Commendable
Oct 14, 2016
26
Hello, which motherboard should I choose for Ryzen 5 1600 ? I probably make some light OC.
This is what can I get from my local store.
1. https://www.msi.com/Motherboard/B350M-BAZOOKA.html 74€
2. https://www.msi.com/Motherboard/B350M-MORTAR.html as I know it's identical to Bazooka with just few more functions. 80€
3. https://www.gigabyte.com/Motherboard/GA-AB350M-Gaming-3-rev-1x#kf 78€
4. https://www.asus.com/Motherboards/PRIME-B350M-A/ 76€
Also I can buy https://www.asrock.com/mb/AMD/AB350M%20Pro4/index.asp but after some recent negative reviews about freezing I just don't want to risk.
So which should I buy ? MSI Bazooka is the cheapest and it looks good for me, what about OC with it ? I'm not aiming to push everything from R5 1600 , just light OC since I will be OC'ing for first time ever :D
Asus one will probably have the easiest bios to use out of them, but the power delivery to the CPU has no heat sinks.
I would expect more long-term stability from either the MSI or Gigabyte as they both have proper heat sinks.
basdxz
71
