Hey, currently having an issue with my pc. At random times, or as soon as you give computer some heavy load, for example starting a game, screen freezes for a couple of seconds, all of usb devices start flickering(turning off and on) and most of the times they stop working and I need to restart my pc for it to be normal again. This isn't my mouse/keyboard/mic problem since I tested it on other PC. What I tried to do was:
Monitor my temps when that happens
Reset bios
Reinstall Windows
Update/remove and reinstall drivers
Updated all of my other drivers
Unticked all of the boxes that said let windows turn off device to save power
Disabled USB selective suspend
Messed around with my pc for hours, cleaned the dust, took everything apart and put it back on and yet no luck.
Checked event viewer, and found abosulutely nothing.
Spent hours looking at similar people problems and nothing helped.
Did memtest, gpu test, cpu test, all sorts of tests which I found on some forum and everything showed up great.
Most times when this thing happens is:
After booting in a game called Rust(I use it to check whether I fixed the problem or not, since it happens 100% times when I launch it)
After leaving my online class call(as soon as I press the button to leave the call)
Randomly scrolling my internet browser
Even when typing this(this is my second take at writing this, since the first time I wrote this the thing happend and button "V" started to press itself and I had to restart yet again.
My specs:
AMD Radeon R7 200 Series
Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz
8GB of ram
1TB HDD
Gigabyte MOBO, not sure how to find the full name
Basically reinstalling windows didn't help so I think it must be a hardware issue? Motherboard, PSU? If u have any ideas what this could be let me know, because it's really frustrating when I have to restart my pc in the middle of a online class!
Reset bios
Reinstall Windows
My specs:
8GB of ram
1TB HDD
