[SOLVED] Motherboard stuck on VGA led on ez debug
Jun 19, 2021
4
Hi, my build is:
  • Motherboard: MSI B560M PRO VD
  • CPU: intel core i9 10900F
  • RAM: OLOY 3600 MHz ddr4 (2 x 8 gb)
    I finished building it some hours ago, I booted it up, there were some white lights on the board, the fans were spinning, but nothing showed up on the screen, then I noticed that on the ez debug section of the motherboard, there was white light stuck on VGA.
I have no display, so I can't access BIOS.
I need to know is the problem from the MB or from CPU , i bought both from Amazon so I need to decide which one I should return.
Do you have a graphics card installed? Because that CPU and ALL "F" model Intel CPUs, do not have integrated graphics.
Without a graphics card installed, you will never have any display output.
Yes, there are graphics outputs on the motherboard but they ONLY work if you have a CPU model that has integrated graphics. Yours does not. If you had a model WITHOUT an "F" on the end, then it would work. With an F model, it can't, because it does not have it and it must have it in order for the video outputs on the motherboard to function.
https://www.pcworld.com/article/333...-gpu-and-probably-arent-worth-your-money.html
