G
Guest
Guest
Hope someone can help, here's the situation:
Building my own machine, just received the motherboard, cpu, fans, case, etc. Here's the pertinant information.
- Athlon Thunderbird 1.1 Ghz
- Aopen AK73 Pro Motherboard (CPU, fan, and motherboard all supposedly integrated and tested by TC Computers)
- 256 RAM, Kingston I think, single DIMM
- 300W power supply
- Maxtor 15 gig HD (works on old machine)
- Hercules Prophet II GTS video card (works on old machine)
Trouble is this; I set everything up, connected all the cables, set all the switches on the board, make sure all connections are in, etc. I hit the power, and nothing happens. Fans don't spin, lights don't come on, nothing happens at all.
I had a local shop test the power supply, they said it's working fine. I've tried removing drives (though I'd think if it was a drive compatability issue, it would at least start up). I've tried removing cards, trying with an older AGP video card, etc. No luck.
Any ideas on what to do next? Is there a way I can verify that this is a fried board, if that's what it is? If so, what process/equipment do I need to verify that?
any ideas or suggestions would be much appreciated. Please respond to ihogan@mbsnav.com. Thanks,
ian
- 300W power supply
ian
