[SOLVED] Moving To SSD problem
Mar 16, 2020
So Recenlty I have just moved my os by cloning it to my SSD. The process was fine and I booted form my ssd and everything worked perfectly. After checking my disk management i realized that i couldn't format it for some reason. It still says that windows is installed on it even tho I already booted from my SSD can someone help please? MY SSD is the F partition and My C is my HDD
Heres what it shows in disk management
View: https://imgur.com/3LDCMFu
You went from the 500GB HDD, Disk 0, to the 120GB SSD, Disk 1?
If so, you have NOT done it correctly.
Your Windows is still running from the HDD, that C partition.
