Archived from groups: microsoft.public.windowsxp.basics (
More info?)
Is the user name column empty? Or missing? Are there applications listed that belong to System, Local System or other machine accounts? If the name column is empty:
http://www.winxptutor.com/tmuserblank.htm
If its missing, go to View, Select Columns and make sure the User Name column is checked off.
Doug Knox, MS-MVP Windows Media Center\Windows Powered Smart Display\Security
Win 95/98/Me/XP Tweaks and Fixes
http://www.dougknox.com
Per user Group Policy Restrictions for XP Home and XP Pro
http://www.dougknox.com/xp/utils/xp_securityconsole.htm
Please reply only to the newsgroup so all may benefit.
Unsolicited e-mail is not answered.
<billurie@nospam.org> wrote in message news:etZ2WZXtFHA.2072@TK2MSFTNGP14.phx.gbl...
> billurie@nospam.org wrote:
>> Doug Knox MS-MVP wrote:
>>> If the value is there, it will listed as MSConfig in the right pane.
>>> When you refer to Diagnostic Startup, are you talking about the
>>> operating system or MSConfig itself (Diagnostic Startup is selected on
>>> the General tab)?
>> Sorry, Doug, perhaps I was not specific enough.
>> I did Run>>MSConfig>> (General Tab, where it always starts) >>
>> there are 3 choices: Normal (which I'd like to get back to),
>> Selective, and Diagnostic (which I'm stuck in).
>> The problem is in a system on another HDD, so I'll power down,
>> swich drives, power back up, look again to be sure, and be back
>> her in another half hour.....
>> WBL
> The half hour became an hour and a half, largely due to extra
> checking to avoid being chastised for overlooking the 'obvious'.
> It is indeed as I said. Of those 3 choices, I'm set with the radio
> button in General Tab on Normal, but when it is finished booting,
> Task Manager shows all applications but no user's name. Proof is
> that PF usage is 85 MB instead of a usual 200 MB. I've gone around 3
> times, and I've done a full chkdsk/r in between (finding no prob)
> and it's as I describe.
> Bill L.
