Question MSI motherboard weird LED pattern
aikorush
41
So recently there has been something weird going on on my motherboard
I have a MSI B350 PC Mate motherboard
I have just upgraded my RAM from 8 to 16GB last week
My RAM is 2 sticks of Crucial Ballistix Sport DDR4 2400Mhz RAM 8GB
So once i upgraded it worked, the first time i attached it, the PC bootup nicely and i can play BFV really smooth now too
The weird problem is whenever i shut down or reboot the PC
It wont boot up at all
The PC starts but there is a LED pattern i discovered
The CPU and DRAM lights up one after another, turns off then turns on again one by another. The pattern repeats
Originally it shouldnt repeat and should light up the VGA and BOOT LED later
The only way i can make it boot up is, if i remove 1 stick of RAM, and then start the PC(Memory changed message comes up) then after i shutdown i put in the 2nd stick of RAM again. Then it works again
It has always been like that
So any idea what is going on, the RAM is a brand new one too and both are the same model too
Please list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Are you on the latest BIOS update for your motherboard? How old is your PSU? It'd be a good idea to pass on a link to the sticks of ram you have or an image of the two sticks, that you're working with.
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
MSI B350 PCMATE
16GB of Crucial Ballistix Sport DDR4 2400MHZ
GTX 1080 FTW
AMD Ryzen 1600 3.5Ghz
Win 10 64 bit
Samsung Evo Pro SSD
600W cooler master PSU
https://www.crucial.com/usa/en/memory-ballistix-sport
This is the ram I have
I think the last time i updated bios was an year ago
My PSU is around 3 years old rn
