Question MSI X670-P PRO WiFi ATX Motherboard takes 35 seconds to boot up. EZ Debug lights stay on for 25 seconds.
Nov 8, 2022
27
Hello, I'm experiencing similar problems to this post: View: https://www.reddit.com/r/MSI_Gaming/comments/yl6bki/new_msi_pro_x670p_wifi_build_slow_to_boot/
On the motherboard, both the CPU(red) and DRam(yellow) light lights up for 25- 30 seconds, then the lights turns off and runs windows/games fine.
When restarting the computer, only the DRam(yellow) light shows up for 20 seconds, then it turns off and system boot up normally.
I don't understand how the EZ Debug light can stay on for that long before my motherboard detects my PC components, since when the lights turn off, windows and games boots up fine and fast.
I have a Samsung 980 pro nvme SSD, so this is a very slow boot up time.
Motherboard: MSI X670-P PRO WiFi ATX Motherboard
CPU: Ryzen 7 7700x
Ram: Corsair Vengeance DDR5 32GB (2x16GB) 6000MHz C36 AMD Optimized Desktop Memory
PSU: CORSAIR RMX Series™ RM1000x 80 Plus Gold Fully Modular ATX Power Supply
NVME SSD: Samsung 980 pro
Any help would be greatly appreciated :)
How are you cooling that processor? Which slots are the rams populating on the motherboard? As of this moment I can only see a Beta BISO listed on MSI's support site for your BIOS. Which slot is the SSD populating on the board? Speaking of storage, is the drive or OS recycled from an older build?
Thanks for the reply! I'm using BeQuiet be quiet! Dark Rock 4 CPU cooler.
The ram is in DIMMA2 and DIMMB2 . The OS is freshly installed on a brand new Samsung 980 Pro nvme ssd.
The red(CPU), and yellow(ram) lights both turn off after 20 seconds. If I restart the PC, only the yellow lights turn on, also turns off after 20 seconds.
This happens every time without fail, and my PC runs perfectly fine afterwards
Same issue trying to find a solution.
I have same CPU, 5600MHz, using an AIO 240mm for cooling, same SSD
Hey,
After some research, it seems like an am5 x670 boards issue. It could improve with future BIOS update. For now, people are recommending turning ong Dram Training in BIOS to speed up boot time.
Exact same issue.
48 second boot time.
Custom Build through Microcenter 2023.
Trying to find a solution. I have fast boot enabled.
System Specs:
Systemboard: ASUS PRIME X670E-PRO WIFI
BIOS Version/Date: American Megatrends Inc. 0821, 11/15/2022
Processor: AMD Ryzen 9 7900X 12-Core Processor, 4701 Mhz, 12 Core(s), 24 Logical Processor(s)
Cooling: DeepCool AK620 High-Performance CPU Cooler
HDD: Samsung 970 EVO Plus NVMe® M.2 SSD 1TB
Installed Physical Memory (RAM) 32.0 GB
Stop Watch - 48 seconds Total Time to land on Windows 11 Login screen -
Time Stamps:
00:00 - Amber LED on mobo
00:18 - Red LED
00:26 - White LED
00:27 - Green LED
00:30 - No LED
00:36 - Splash Screen "ASUS In Search of Incredible"
00:48 - Windows 11 Boot Screen
