Hello,
I got an i5 11600k & RTX 3070 System with a pair of 16GB 3600Mhz Gskill Hynix RAM.
No matter what I do, I couldn't be able to run them over 2933Mhz.
Here are the solutions I tried:
What odd is, it did work on 2933mhz with 1.45v and 1.35v both. So this is not a voltage problem.
People on the internet are able to OC their ram with the exact same RAM.
My system is 3 months old, components are brand new
I am normally not a forum person, but this issue left me desperate for help.
Anybody has a suggestion? I would be really glad for some wise advice.
Thank you very much!
Please see my actual CPU-Z Informations below:
- MOBO is up-to-date. F8a.
- Tried on 1. and 3. Sticks, succeeded at 3600mhz but wasn't stable at all. Crashed repeatedly. While on those sticks, I tried till 1.45 Volt and different timings, didn't succeed either.
- MOBO suggests them on 2. and 4. sticks, I've located them so.
- Optimized defaults loaded and xmp activated, didn't work.
- Tried to set everything manually as suggested
- Tried between 1.35v and 1.45v
- Tried VSOC 1.150v
- Tried a lot of different minor settings on BIOS
- I did read this guide completely: https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md
- Timings: https://ibb.co/VVV2G3Q
- SPD1: https://ibb.co/G0qhgN5
- SPD2: https://ibb.co/GpYrh0Y
- Memory: https://ibb.co/pvST6JT
- CPU: https://ibb.co/0JmsJ6G
- Motherboard: https://ibb.co/HnBBqXR
