[SOLVED] My Cooler Master Devastator 3 Mouse LED won't change and it's stuck on red
The mouse was working fine yesterday, but now i cant change the colours. Is there any known reason for this? And if there is how do i fix it?
Did you try cycling the colors as stated in the manual? If that doesn't change your experience, might want to take the mouse to a donor system and see if the same issue is seen on donor system/laptop. If it happens there as well, then the mouse conked out with the color cycling function.
Thankyou for responding, and yes i did try changing them like the manual did but it didnt change anything. But luckily the mouse still works fine but the colours don't
