Question My Corsair Vengeance LPX 32GB (16*2) 3000Mhz not working with 3700x
Jul 30, 2019
7
Hey Fam,
I am new into pc building and a couple weeks ago built a new pc after waiting for so long for the ryzen 3rd gen cpus.
I am using Ryzen 7 3700X
Gigabyte Aorus X470 Gaming 5 wifi
RTX 2070 Super
After all the latest bios updates i enabled XMP so that the ram could run at the advertised 3000Mhz Speed and it did run quite well until i started getting BSOD of different kinds every hour.
I wasn't sure about the reason of it but i thought either the ram or the mobo would be the root of the porblem but now i have disabled XMP and my ram is working at 2133Mhz and it seems the system is stable now so what should i do ? Should i change the ram ? or should i check manually the voltage and multiplier of the ram ?
Hey Fam,
RTX 2070 Super
Do you having any problem with real time latency on that RAM at stock speed?
Hey man,
I had a similar issue on an old Ryzen 1600 system I had. My 3200mhz RAM was causing BSOD on my system, but only if I overclocked my CPU. I had to find the sweet spot between overclocking my CPU and RAM, which was at 3.7Ghz and 3000Mhz. It's not ideal but this is a temporary fix until you find something more long term.
Personally, I never managed to achieve 3200Mhz on 3.7Ghz but after doing some research online I've learnt that it can be due to a couple of things. Either the RAM is just not responding well to the system in general (so CPU and/or motherboard (but mostly motherboard)) or either you're having a temperature issue related to the overclock, which is something you often see in Ryzen systems.
Hope this helps a bit. Good luck.
